A6 c6 v6 tiptronic bouncing under deceleration
Diskutiere A6 c6 v6 tiptronic bouncing under deceleration im Motor, Antrieb, Abgasanlagen Forum im Bereich Audi Technik Forum; Hi everyone, sorry for my post in English but I am not enought skilled to post in German. My a6 c6 has a quite strange behavior, it is a 171kw...
  • A6 c6 v6 tiptronic bouncing under deceleration Beitrag #1
Jeremie
Jeremie
My a6 c6 has a quite strange behavior, it is a 171kw Quattro tiptronic diesel from 4/2007.
Basically upon acceleration there is absolutely no problem the car shifts good and torque converter is quite stiff and does not slides under strong throttle .
it is when and only when I release my foot from the accelerator pedal that a problem happens
the problem occurs when the car shifts down. At each gear change the engine speed increases due to the engine brake phenomena but just after that the engine speed is bouncing from about 200 rpm and this I can feel it when the car is deceleration it makes it shaking me.
the phenomena ends only when i am near to be stopped.
have you ever seen that ?
I have searched a lot on internet nothing on French and English forums ...
I have recently made an oil change, and it has changed nothing...
i was was thinking to solenoids but no error code found with VCDS ...
I have tried to initialize the gear box to make new learning so but it did not changed anything
so the two only thing I had in mind were :
1/ the mecatronic unit which could be dirty or have a solenoid not moving correctly
2/ a wrong software or not to up into my gear box ... Do you think this can be a root cause ?
A6 c6 v6 tiptronic bouncing under deceleration - Ähnliche Themen
Automatik auf Schaltwagen umbauen: Passive you Đang Đàn Đỏ Trọng việc LUA choose chiếc Đồng Hồ PHÚ hợp cho rieng Minh Thị Đồng Hồ nam Casio AQ-S810W-1A4VDF as a Among NHUNG MAU Đông...
Car engine for Audi 1,8 t: Dear all, A couple of months ago, the engine of my car, Audi type, has collapsed. Mechanics told me that I have to replace the engine with another...
Technical probleme: You can reply in Deutsch: My 2007 A6 Allroad is running fine, but I’m having 3 minor problems, that I want to fix myself having the VAG PC: 1.-...
VAG COM (Audi,SEAT,Skoda,VW) Fault Codes: http://repair-manuals-download.jimdo.com/audi-fault-codes/ 16394 P0010 Series 1: failure of the regulator valve timing 16395 P0011 Series 1...
New Original Pioneer DDJ SZ Professional DJ Controller..$800: Return Policy By buying on an item, you agree to the following: In the event that a buyer chooses to return an item within 14 days from the...
